Want to share Suzuki and Evinrude gas tanks?
TwoRivers
Hello all!
Not sure where to post this so I thought I'd try here?
I've got two six gallon gas tanks.
One has a Suzuki connector which appears to be a 5/16 male threaded into the riser from the tank.
The other has the Atwood USC (universal sprayless connector) which appears to be 3/8 male threaded into it's riser.
I'd like to convert the Suzuki tank to the USC but I can't find a fitting for the conversion.
I'm guessing that it should be brass but the current ones are plastic.
Anybody have any ideas.
Many thanks in advance.
Rob
Frank Acampora
Re: Want to share Suzuki and Evinrude gas tanks?
Does the fuel line for your Suzuki plug into the front? If so, a standard OMC fitting will fit it so just use a separate fuel line for each tank.
Your best bet on swapping fittings would be to take the one you want to change to a plumbing supply house. If the tank is plastic, you may be able to re-tap it to 3/8 NPT.
That's all I have.
