There will be a gray wire inside your control box which is the tach feed. You "might" actually have a small plug in exposed on your control box . The tach wiring is very simple. It gets 3 wires....... positive, negative and gray wire. The only other item is to set the pole switch on the back of the tach to the proper setting.
