Re: wards sea king 7
No trouble at all!<br /><br />The 5hp SeaBee was manufactured for Goodyear by the Gale division of OMC in 1947. You might know the Johnson, Evinrude, and Lawnboy devisions better. This engine is basically the same as the old Johnson TD series engines ('41-49). Fuel/Oil mix for that one is 24:1 87 octane gas and TC-W3 outboard oil, and the spark plugs should be Champion J6C gapped at .030". J6C replaces the J6J, which is no longer made.<br /><br />I know that a lot of those 5hp engines are still running today, and people think very highly of them. I also know that usually nothing seriously goes wrong with their ignition systems. So you may want to try simply pulling the flywheel and cleaning and gapping the points to open .020" max,and see if spark returns.<br /><br />Best manual you can get for that one is the factory one from kencook.com, maxrules.com, marineengine.com, or theoutboardwizard.bizhosting.com .<br /><br />Hope that helps!
