Warm engine dies
ktbarrentine
Re: Warm engine dies
Rob... Respectfully recommend you transfer your posts to a new thread. You'll get more specific help and it wont get confused with Bones' issue, which appears to be a different problem. Best of luck!
bones774
Gas blowing up and out carb like a geyser when it stalls.
bones774
Update-Took it to local marina and he replaced the pickup inside dist, so it works. He said he got no spark condition whereas i was starting it fine when cold. Now i notice a black wire with a ring terminal disconnected and hanging by the coil, i traced it to port side riser, there is a electrical plug there and the black wire is the bottom wire should i have the ring term connected somewhere?
Thnaks
bones774
Bumping if anyone can answer post #25
Thanks
bones774
i noticed a black wire with a ring terminal disconnected and hanging by the coil, i traced it to port side riser, there is a electrical plug there and the black wire is the bottom wire should i have the ring term connected somewhere?
Thnaks
Hi does anyone have an answer? Thnaks
