Re: Warning Alarm for VRO failure? 1995 150 EXEOM
When the System Check was introduced, they ran into trouble with some engines not delivered with the System Check instrument, rev-counter or the round Sytem Check gauge. Those engines, 9.9/15 and 25/30 was delivered (retro fitted) with a special horn driver box in order to make the System Check alarm horn work properly.
Not having individual leads from sensor/switches to the instruments all the way will somewhat 'confuse' the system check alarm indication.
An old VRO tank as well as No-Oil will give a constant alarm, same as temp and fuel-restriction, not quite sure which light will be triggered, but in all cases the same light. A system check VRO oil tank in an old system, will give a constant alarm like Temp alarm. Which horn you have may easily be identified as the old horn should be a 3-wire, the System Check a 2-wire with a 12" extension cord and a Deutz contact in the end strapped somewhere under your panel.
