Could someone please answer this question. I have a 1999 150hp Johnson OceanPro with only 15 original hours since it's purchase new this year. The other day I was about an hour out into the ocean when the buzzer started going off. I immediatly shut the engine down to look for the problem. Water was streaming out of the cooling tube with a healthy stream. The oil was not low however, to be safe, I poured oil directly into the fuel in case the pump had stopped working. The engine did not seem hot and the overheat light never did come on. Finally I pulled the fuel filter off of the front of the engine to check for dirt, water, and fuel flow. I found no dirt, no water, and fuel flow was great. Being this far out into the ocean I decided I had better get back in so I had to run the engine, with the buzzer running, for an hour to get back to the ramp. I pulled the boat home and reinspected for any problems. Again everything checked fine. The very next day I went out, turned the key to the on position, and immediatly the buzzer started going off. I am stumped, after sitting for 24hrs. the engine could not be hot, there was no need for fuel flow, water flow, or oil flow, since I did not start the engine I only turned the key to the on position. Does anyone have any suggestions? By the way this is a caburated model, 6cyl. 6 Carbs. Please help.<br />Brad Heil<br />bradheil@dmv.com
