pcrussell50
Thread starter- Joined
- Sep 21, 2008
- 296
going through a boat i bought after only a cursory inspection. one of the things i go to check is the overheat warning buzzer, so i do the usual... i jumper from the brown wire coming out of the sensor in the head, to the hot positive lug on the solenoid... and all i get is a weak chirp... continued...
the motor is a v4 crossflow outboard, but with a hotfoot throttle and billet shifter and the warning buzzer mounted under the dash. i have no idea where the guy who restored and modified this hydrostream viper boat got the warning buzzer, but i want to find out. when i look at the ones that are mounted inside the remote controls, those things are INSANELY expensive for what they are.
so i go under the dash and remove the buzzer to test it directly against a fresh battery, in case there are some bad connections between the sensor on the motor and the sensor under the dash. before it test it, i inspect it, and find some dirt or detritus in the speaker "bell", so i poke and blow it out. some kind of bug, maybe? now i throw it on a fresh battery, directly, not through the boat's circuits, AND? same thing just a chirp. i can get the chirp to repeat if i detach power, the put it back on again... chirp! remove, reattach... chirp! repeat.
anyway, i cannot believe both how hard these things are to find and how expensive they are. since it's now installed under the dash, i don't feel like i need any special svelte shapes that have to fit inside a remote. i reckon all i need is any old 3-pole horn, but i don't even know how to search for one.
any ideas?
-peter
any ideas?
-peter
