Warning Horn
Dean Eechaute
i have a 1993 175 Johnson Fast Strike. It appears that the warning horn does not work. Where is it located and is there a wiring drawing for this circuit? This horn warns if oil is low or empty or if the engine is overheating. It is suppose to give a short beep when the engine switch is turned on.
R.Johnson
Re: Warning Horn
There is a tan wire coming from a heat sensor on top of the cylinder head. Strip back the insulator on this wire. With the key on, short this wire to ground. The horn should blow.
seahorse5
Re: Warning Horn
Only late model horns will beep when you turn the key on. They are recognized by a separate black ground wire that has to be hooked up, in addition to the purple hot wire and the tan sensor wire.
