Warning horn
Bloomer
Hey, Great site my ? is i want to hook up a light to my warning horn so when the horn sounds the light will come on and need to know what color to hook to its a 200hp johnson 1990. Thanks
12Footer
Re: Warning horn
Welcome to the board.<br />My brother was a deaf mute, and we rigged his boat with bright, flashing white colored LEDs, available at radio Shack for a buck apiece. You will need a resistor inline for those tho, as they operate on 1-3Volts DC, and the buzzers are 12VDC.<br />Of course, you can use 12volt auto dash indicator bulbs too, and they are a tad cheaper...Just aren't as pretty.<br />LEDs are polarised, so they have a + and - end. But the car lamps are not, so it does not matter which goesw where. Just put it accross the posts of the buzzer. Instant light.
jegervais
Re: Warning horn
The horn is wired with purple (12+ when key is on), and when the alarm sounds, the tan wire completes circuit by supplying the ground. Some older horns used a third wire (black) - which ever the case, you want to hook up between purple and tan.<br /><br />-John
12Footer
Re: Warning horn
And I just remembered something...Another reason we used the LEDs as opposed to the auto lamps...Current. The senders are only able to deliver switching current,and a high current bulb may ruin them.You can get around this by installing a relay accross the buzzer terminals, and the lamps to the relay's switched terminals.<br />You don't need to worry about current draw when using the LEDs because they are very low current (lower than the buzzer for sure).
petryshyn
Re: Warning horn
Bloomer:<br /><br />12'er is right. You'll need a resistor in series with the LED. I'd recommend a 'super bright' red LED with a resistor value of 330 OHM 1/2 watt. Believe me....it'll get your attention!<br /><br /> :)
