Warning sound?
Lck7960
On my 2005 sea ray 185 sport, when you start boat there is a beeping noise and then it stops. Lately, it keeps going until you accelerate and also beeped when we went over waves. Seems to beep again when deaf celebrate. Anyone know what this is? A warning is some kind? This is our first boat.
xheadrasta
Re: Warning sound?
It is defintely a warning. I believe that I've either read here or on the Stingray owner forum that the alarm will sound when starting, in an over-heat situation and possibly oil pressure. I'm not 100% sure on those maybe someone else with a little better knowledge will chime in.
Cheers,
Scott
roscoe
Re: Warning sound?
Huh?
Yes a warning.
No owners manual?
Engine ? outboard or i/o ? Make and model?
etracer68
Ensign
Re: Warning sound?
Maybe decelerate?????? I had to say the words together a few times to come up with that.:rolleyes:
NHGuy
Re: Warning sound?
It's probably the Mercruiser combination beeper that monitors high temp and low oil pressure. Check your oil and watch your gauges, either item can cause big repairs, that's when it warns you.
Deaf celebrate has got to be a phonics version of decellerate, to slow down. Was this original post from a voice to text device?
etracer68
Ensign
Re: Warning sound?
If a voice to text, and they call these things SMART PHONES:eek:
JEBar
Re: Warning sound?
OK .... thanks, I got it ..:)
Jim
bekosh
Re: Warning sound?
If you have a remote fill bottle for the drive oil check that too.
emilsr
Re: Warning sound?
That is your boat's way of telling you something is wrong. Don't run it again 'till you find out what that something is and fix it.
There's no shame in taking your boat to the mechanic if you're not sure what the problem may be, but there is shame in not fixing it and doing a lot of needless damage to the powerplant by ignoring the warning beeps.
kobe
Re: Warning sound?
Sounds like the drive lube monitor. Should be a small clear white bottle on the top left hand side (front) of the engine. It goes away when you accellerate because the sensor is in the back of the bottle (is on mine anyway) - bottle becomes angled (with the rest of the boat). when you go over waves or deccelerate then the lube oil moves forward in the bottle and uncovers the sensor giving you a low level alarm.
Lck7960
Re: Warning sound?
Thanks for all your help - will definitely get it checked out!
BobGinCO
Re: Warning sound?
Shhh... He's celebrating with the deaf! Or hunting wabbits!
