Washing the inside of your outboard motor?
mmuutts
Any thoughts on using a engine clean/foam on your outboard then hosing it off..Good or bad idea?
ajgraz
Re: Washing the inside of your outboard motor?
Cover the carbs (and distributor if it has one) and go to town.
Bob_VT
Yup avoid the carbs and do not spray inside or under the flywheel. I have used napa spray brake parts cleaner which dries fast.
Sixmark
Master Chief Petty Officer
and if you are worried about being eco friendly you can use Simple Green
Bob_VT
:redface: yeah...... I'm not :eek:;)
Sixmark
I merely put that out there for those that think it will offset the amount of gas/oil left behind by a 2 stroke.....lol
robert graham
I just rinse motor with a garden hose without a nozzle so no great pressure to force water into places you don't want it. Then after it dries, use WD-40 and an old toothbrush to clean all around in tight places. A thin film of oil/lubricant on all surfaces may protect from moisture/corrosion. Once you get motor really clean, it'll pretty much stay that way with a minimum effort and no strong detergents/solvents. Good Luck!
emoney
Nothing wrong with a little de-greaser too. I like a clean motor because it's easier to see "issues", in my opinion.
rickryder
A clean motor is a happy motor :D :D
mmuutts
THANKS! Time to get out the tooth brush....
