Waste water level indicator panel
peidude
New owner of 2002 Signature 260. Any thoughts on how to get info from this panel? By the way, the User manual is borderline useless 🙄63D6ECBC-1AD8-4CF1-B069-C76E6CDA77BE.jpeg
Grub54891
Yo have to find out of the gauge at the tank is hooked up/installed properly/or bad. Or it’s not hooked up at the panel.
peidude
Thanks for the suggestions… as noted, I just purchased the boat and not familiar with all the inner workings yet. Would you happen to know where the “tank “ is located. Diagrams I have seen look like just forward if bilge/engine area.
Grub54891
You will have the follow the fuel, lines and figure it out. Some have no access to the sender or hookups. You have to carefully create them.
