I was out on the water and my water pump failed. The engine overheated to about 240 f. Imediatetly i turned off the engine, and got towed in. Replaced the water pump and it started right up. it was running a little rough but i thought it was just the normal shake of that motor. Later i pulled the plugs out, and come to find one is not firing. Changed the plugs, wires distributer and still it doesnt fire. But the engine runs and drives fine on 3 cylinders. after i let the engine warm up to about 160 for about 20 mins i shut it off. the next morning i took the plug out that was not firing. I find it is FULL with water and rust specs in the cylinder!! Please could someone give me some advice to what to do from this point?
