lucky7's
Thread starter- Joined
- Jul 9, 2008
- 74
I have a 2002 Mercrusier 6.2 mpi raw water cooled engine. Recently I have developed a problem. I noticed the temperature gauge fluctuating from 160 to 190 up and down constantly while running at speed on a plane. However it does not overheat at any rpm (WOT or idle). The temp does not fluctuate at low speeds. With somebody driving the boat at speed I can crawl back and watch the water coming out of the thru hull exhaust. The left pipe blows plenty of water out. The right side will blow water out fine and then stop and then blow some more out and then stop at about 5 second intervals. This correlates with the temp fluctuation. At any speed below a plane it works fine and blows water out constantly. Ive checked the exhaust riser on that side and there appeared to be no restriction. Also i am in the process of replacing the thermostat it has never been replaced. The seawater pump is only 2 years old and I bought a brand new one not a repair kit. I am thinking the thermostat is opening and closing back and forth and even though the water supply does not need to go through that for the wet exhaust I think it is temporarily disrupting the water flow. Any one that has any advice would greatly be appreciated. Thanks Fred...
