TriadSteeler
- Joined
- Oct 26, 2006
- 237
This was part of a thread I have going on the Boat Resto forum, but my particular question fits better over here.
It is in reference to a 1974 Merc500 (3823131). I have rebuilt the carbs, new plugs, water pump assembly, new internal harness, and fuel hoses.
Finally got an opportunity to get back to the motor. Hooked it up to a new battery, new fuel tank, and the muffs. After about 3-4 seconds with the choke closed, she fired right up after 10 years dormant and idled like a champ.
Here is my first issue. How long does it take for water to come out of the pee hole. I shut her down after about 15 seconds because I didn't want to burn up the powerplant. Is there any way to flush the cooling system and make sure water is getting into and thru the jacket without running the motor.
I had water coming out from the prop exhaust while it was running and some lazy smoke was coming out of the upper exhaust ports after I shut it down. Before I started it, I made sure that the pee hole was clean at least into the rubber hose that is inside the cowl. I also replaced the entire water pump including the impeller.
