I finally got the motor running. 55HP 1971 Chrysler. It is in a large lawn can filled with water. As I let it run for a minute I did not see any water coming from it. The water was churning hard. I could not get it in neutral. It is submerged more then half way up the lower part. Where does the water enter and exit from. Could it be it is coming out from the lower part and that is normal? I just put in a new thermostat and faced the point toward in the head. Is that correct? Can you give me some things to check.
Thanks
Thanks
