j_k_bisson
Thread starter- Joined
- Oct 6, 2010
- 1,082
To start off I have a 1987 225 Evinrude that I rebuilt/restored. I just finished 3hrs of breakin and I am asking questions about certain things that have popped up. That is why this thread is being started.
The motor's water cooling system was rework as per Faztbullets suggestion to remove the whole water control valve and diaphrams, seeing some parts are not longer available, and replace them with a late 80's 70hp T-stats covers, spring and T-stats. This worked out great seeing it was already done to the motor when I got it. I replaced the springs and and T-stats and reused the covers.
I also installed the OMC Head temp sender and gage in the boat to motonitor the temp while running. I had an issue with this right off the bat seeing I bought the sender and gage separate from each other. When I first started it up, and the motor warmed up, the gage spirked to the limits. I found that the sender unit did not match the gage I was using. I have corrected this on the motor.
While out running the last time, while still in the breakin stage, I notice that the motors temps are around 165'f at idle, 650-700rps. This is high as per the service manual. Tha manual states that the temp should be 140'f +/-15'f. At 2000rpm approx the temp rises to185'f. That is untill the t-stat's unseat and the temps drop to 120-140'f.
I have talked to my local dealer and they are telling me this is not really an issue. I have gotten feed back from members on this site and they stated I should be concerned. That is why I am starting this thread.
First off I am asking anyone else that has this same setup what are you reading on your temp gages. Also what style is your temp gage are you running.
I am lead to believe that this could cause premature failure/wear to the motor with the sustained temps. I plan on using this boat in rough seas and the speeds I will normally use it at is 2500rpm rage. Basically just up on plane. So this could become a big issue for me.
The next question is how can I over come this issue? Or better yet how can I lower the temps? If it where a typical T-stat from a car I would just drill out the pee hole in the t-stat and call it a day. But these T-stat's are a bit different monsters. Is there different Verbatums thingy's for different temps? I am assuming the Verbatums are inside the t-stats.
Or am I making a big deal out this whole temp issue?
And yes I have replace the water pump as a whole. It is installed correctly and working correctly.
