water cooling problems pump is good!!!!!
zildjian29
there is a brass bolt in the top of the powerhead water will come out of it when it is out. but still wont come out off pee hole. please help!!!!
79Merc80
Re: water cooling problems pump is good!!!!!
A little more information is needed for an informed answer. Year, Make, Model, HP, # of cylinders
zildjian29
1968 merc 500 50 hp 4 thunderbolt.
79Merc80
Take the hose off the brass fitting and blow air from the **** hole. Sometimes bugs make a nest in there.
hotrod53
take a piece of 18 gauge insulated wire and shove it in the pee hole, sounds like a proceeduere I had done once ... LOL. If you have water coming out of the brass plug, you have waterflow and most likely you are safe, you're just not peeing. Had to do it on my '77 Merc 500 4 cylinder.
