Re: water dripping from shift lever.....57 johnson cd 14
You have to pull the powerhead to work on the water pump, so it is a great time to fix the leak. Remove the screw from the inner shift lever (inside the housing) and slide it off the shifter shaft. Then pull the shifter/shaft out of the housing and replace the o-ring. Warning!! That inner lever will break if you attempt to shift it with the screw removed.
