Hello,Everyone.I'm a bit curious on the vernatherm/relief valve/thermostat housing water flow.This is on a 1970 85 hp 'Rude.There is two outlets on the waterpump and two water pipes going up to powerhead.The way I understand it is the water flows up from pump into vernatherm housing,if vernatherm is closed water flows back to lower unit through poppet valve on other side of vernatherm housing? Is this correct? The starboard side of this engine seems warmer than the port side? I've verified my vernatherm is functioning,(pan of water,143 degrees) it just seems a little strange.Anyone care to explain the process? This is a great site,I appreciate the informative answers that alot of people so selflessly give.A good manual and this board keeps alot of us outboarders going.Thanks Everyone,C.C.
