CBGale2
Thread starter- Joined
- Apr 22, 2009
- 1,026
Alright this is my first motor with a thermostat in it, tell tale, and prop exaust so just making sure Im thinking this through correctly on how the water flows and exits.
I hooked it up on the muffs and started it up and ran it for 1 to 2 minutes just to see if it ran. Had an increase flow out the tell tale once it was running so it appeared the water pump increased the flow and was pumping, looked like I was also getting a small flow of water out of the prop exaust. Now what I didnt see was water flowing out the exit vents on the side of the leg, will this only happen once the thermostat opens up and how hot does it get before this happens?
