ljc1957
- Joined
- Aug 30, 2007
- 169
Hello All, I'm replacing the thermostat and impeller on my 1966 Chrysler/Seaking outboard and I'm a little confused about the water flow in my engine. I know the water is picked up at the impeller then, as best as I can tell, it's forced into the exhaust housing? From there, it travels through a plastic hose to the T/stat, where it either enters the head, depending on engine temp, or exits out the down the exhaust port on the middle of the engine leg. If the T/Stat is open, doesn't that exhaust exit on the 2 small exhaust ports on the lower unit? When the T/Stat is open should some water still exit the mid engine exhaust port? I hope that makes sense. Thanks in advance.
