buckeye_paul
Thread starter- Joined
- Sep 6, 2010
- 21
I just bought a boat at the end of last summer. Had it out a couple of times without any overheat issues. I have a 1970 Johnson 85. I just installed a tell tale indicator using posts from this forum. I put the lower unit in a large tub, filled with water, (made sure water was above intakes) and started the engine. Ran in for about a minute and had no flow of water or air pass from indicator. Tried with muffs also, no flow.
Took the lower unit off. The impeller that was in there looked brand new but I replaced it anyway. After I had it all apart I think I realized the problem.
The thermostat had not opened yet. Does anybody else agree? I haven't put the lower unit back on the motor yet. I want to get some idea that my assumption is correct. I haven't taken the thermostat housing apart yet.
