water from lower unit
PG Georgia
I have noticed a small trickle of water coming from the lower unit on my 115 Johnson. The water is coming from the seam where the lower unit is attached. Is there a gasket to replace? there is no water in the lower unit oil.<br /><br />Thanks :confused:
petryshyn
Re: water from lower unit
there is no gasket between the lower unit and the driveshaft housing. A trickle would be normal while running on a hose or just pulled from the lake....... :)
