Water from plug...old question, I know, but....
myelo
I've read all the posts concerning the water jacket issues about water leaking around plugs, but just can't seem to find any gasket or part labeled "water jacket" for my motor, so here we go.<br /><br />I have a '72 Merc 650 and I put a water pump kit on (it wasn't peeing before). With the new impeller, it MUST be moving water cuz it it squirting out around the two bottom spark plugs. I had replaced the gaskets in that area, but I did not put any "liquid" gasket w/it, which apparently is what everyone does. Anyway, I cannot find anything that refers to a "water jacket" for this motor. <br /><br />Also, I see where you all have talked about sealing around the plugs themselves. Not sure what you are talking about exactly. Anyone got a diagram? :confused: <br /><br />Had a "part-time" boat mechanic tell me my motor was fried, that's why water is coming from plugs, since I had replaced the gaskets. I think he just wants me to sell it to him....cheap.<br /><br />Is there something catastrophic that could be wrong to cause this issue? It didn't start until after the new pump parts, but then again, the old impeller was totally gone so who knows if it would have happened before. Thanks once again, for all your help!
myelo
Re: Water from plug...old question, I know, but....
One more thing...I only see ONE gasket for this area, and it is called a GASKET, CYLINDER BLOCK COVER 27-60310. I have replaced this already, but like I said, I used no liquid gasket. Don't know if this helps or not. Thanks again.
b.moon
I have a 165 horse merc, inboard, I have replaced coil,roter,points,condenser,coil wire,distributer,I have put out drive in down possition ,and can't get spark to plugs, have distruter to coil negitive wire, have power to coil, power to points but no power thru coil wire no spark to plugs please reply
molsenice
b.moon - you might have better luck in the inboard forum - My motor is an otboard and I did the same thing. myelo - good luck.
