ohhenrygsr
Thread starter- Joined
- Aug 24, 2008
- 20
Hey guys and gals i have a 1996 Evinrude 50Hp Electric start and my question is that i have removed the VRO system and running Pre-Mix (50:1). The boat came with an onboard Fuel/Water Separator system. So my question is can i run the premix gas through the filter i currently have a direct line from the gas tank to the outboard and where should the primer bulb be located if i where to use the filter system before the filter or after thanks henry
