water housing
Bt Doctur
for mike 2000 , can send the button for draining
BT, looks like someone is replacing the plastic mercruiser crap......
Bt Doctur
The art of doing repairs, thinking outside the box, inventing has long past. Now in this throwaway world you replace. Dont get me wrong, sometimes replacement is the only way but boaters have only so much to spend on their toys.See my shift cable thread repair instead of gimbal replacement. Or see my Bravo pump install on a volvo v8.
keep in mind there are also kits to install the Volvo crank mounted pump an a Mercruiser
Bt Doctur
The latest project due to the fact the previous owner installed 1 inch alum angle on the deck to provide a spot to clip the canvas. The aluminum is now being tested underwater to the dismay of the new owner watching me throw it in the lagoon .Will be replaced with these flush mounted locking system that leaves a flush deck when not in use.
Bt Doctur
tried the crank mount , made sleeves to reduce the wobble, didnt like it or the wobble so I did this. Have never looked back,works perfectly
