Water impeller install on 9.9 ted williams
Apacheuser
Need help wont seperate after bolts removed whats holding it does powerhead have to come off.
ricklum
What kind of shifter is on it. Is it clutch shift or shift rod running down to gearbox.may be as simple as having it in neutral.been a while since I've done it can't remember very good.
brim_buster
Remove inspection cover on the leg and disconnect the shift linkage
ricklum
After u take inspection plate off there should only be 1 bolt to disconnect the shift shaft.take your model# to searspartsdirect.com. they have parts diagrams that show everything.
Apacheuser
I went on sears site the diagrams are fuzzy for my model doesnt show it well enough to tell. Only thing left is to unbolt powerplant and see if driveshaft will release that way
ricklum
Have u taken the nut off that is hidden under the chromed clip on front of bottom housing.it pops off with screw driver
Apacheuser
Yes 2 plus disconected shift link even tore down engine took allen bolts out still wont seperate must be welded togther.
ricklum
That sucks.what kind of force have u put on it hammer and block don't wanna bang anything to hard cast can break easy
ricklum
Do u think someone had it apart before.u haven't missed anything it should come apart
brim_buster
you have a frozen drive shaft probably. Take off prop and remove gears and see if it will drop. I sent you a private message about a manual
