Re: water impeller no water
Hey guys this thread is great. Exactly the same issue I'm having with my '67 3.9 merc. Here's what I've done, and still no water comes out the pee hole:
Replaced impeller that was shredded. It still wouldn't pee water, but it would spit a little bit until the engine started to get hot and then overheat.
Stuck a garden hose on the water pipe, solid stream shooting out the pee hole...so no blockage right?
Took the exhaust plate off the side and found a piece of old impeller inside the channel in the plate. Got it out and still no water out the pee hole.
Started it up with the "clean water flush" plug out and it shoots water out of that hole. Put the plug back in, no water out the pee hole.
So when I start it now it will shoot water out that hole by the powerhead bolt under the cowl for a bit. Then it starts to smoke A LOT and a steady stream of exhaust comes out of that hole and the pee hole. I noticed bubbles in the trash can coming up from the prop while it was running.
So I know it's pushing water up, but it just doesn't make it around to the pee hole. I let it idle for almost 10 minutes today and then revved it up in neutral and drive/reverse and it never overheated (as it has before), but still smokin' like a mother.......
Is it likely that there's blockage by another piece of old impeller in the engine somewhere or is it an issue with the grommet in the water pump hole (i.e. not enough pressure to make it all the way around to the pee hole)? I did notice the little circle nipple on the grommet was half cracked at the base where it attaches to the grommet, but it still stays seated pretty well in the pump housing.
Any help would be great because the weather here in Michigan has me aching to get the boat out, but last fall I drove halfway across the lake and had it overheat on me. Oars suck.
THanks,
Earl
