water impeller?
fishinwithmercury32
I've heard alot about water impellers. I think mine is out. There is no pee and it smokes when it runs. Is the impeller the problem? Will this cause the motor to cut out?
Thanks
narvlebenoit
Re: water impeller?
it will cause the motor to burn up with no water.change the impeller before you run it again
fishinwithmercury32
Re: water impeller?
ok. Then if the impeller is not the cause of it cutting out what could it be? When i pour gas directly into the carb it runs for a second, uses up the fuel, and cuts out. New fuel pump, rebuilt carb...Im at a loss. It finally started running and then cut out. Im getting frustrated. any advice?
Mi duckdown
Re: water impeller?
You need to change the impellar if is not peeing, Period. It's a carb issue you need to rebuild it. But first I would do a compression check to make sure you are not throwing good money away.
fishinwithmercury32
Re: water impeller?
Thanks ducksdown. Im new at this and im about ready to trow this thing through the damn window. Keep ya'll updated.
narvlebenoit
Re: water impeller?
take your time fish I started on a inline six had to walk a way a few times but got good help here these guys are great they will get you going bare with them.Igess you tried pumping the bulb once it starts running.
