dlogvine
Thread starter- Joined
- May 4, 2015
- 839
I was going to remove the engine of my 1993 bayliner capri yesterday. So i thought it would be a quick job to remove the oudrive by myself first and then my friend would have helped me with the engine. However, the task appeared a little more difficult then expecter, after removing prop and trim tabs and then 6 nuts, i jerked the outdrive for a while with no progress. Since the trim pump is not operational, power line was rusted out and this repair was going to be done later i could not use them to pull the outdrive with a wooden wedge. So i tried it for a while, used a wooden bar between the outdrive and the gimball trying to use it as a lever. No luck. So i ended up spraying everything with pcw blaster and soaking it overnigh. today i was going to repair the trim pump, but lucky me, the outdrive peeled of and it was pretty easy to remove it. What i found upon removal was a little rusted shaft, which was most likely stuck and little rust on the outdrive gears. When i started cleaning the boot from old grease i found a decent amount of water there. The question is, is it normal to have water inside there, and if not, which is my guess, what could have caused it there, bad seals, bad gaskets, any other sourse of leak? Looks like the engine compartment was flooded so is it possible the water soak3d from there? And how could i check for the source of water before putting the engine back in? Thx
