wellcraft-classic210
Thread starter- Joined
- Sep 22, 2010
- 839
When doing my winter servicing on my 1988 wellcrat classic 210 with merc 5.0 and alpha one outdrive;
I found milky oil in my outdrive & then found water in the bellows after deciding to pull the outdrive for a closer look
I pressurized my outdrive with a modified fitting mounted on a radiator pressure tester & found that the seal on the propeller shaft leaks at aroud 7 PSI
This has lead to the following questions;
--How is the water getting in the bellows? Are thier other likely sources oother than the bellows itself? (The shift shaft looks suspicioous to me as it spins quite freely. )
--What checks should I be making on the bellows assembly and the outdrive itself before considering resealing it.
-- Anybody had luck in making thier own tools to disassemble the large spanner nuts on the prop and drive shafts.
-- Any other useful advice on attempting this mayself is also greatly appreciated. Thanks for reading!
