fishing603
Thread starter- Joined
- Oct 10, 2011
- 8
I just inherited an '86 cajun bass boat from my grandfather. I used the boat once since receiving it, and left a switch on which ultimately killed the 6 year old cranking battery. I removed the battery and the battery box, to find rotten wood. I started investigating and found that the entire deck in the back was rotten with more than half a gatorade bottle worth of water sitting between a stringer, hull and the rotten deck.
I did a little trial and error to see how the water was getting in there. First, I checked the transom with the end of a screw driver and it sounds completely solid, no dull sounds anywhere! The livewells, checked both the front and back, seem to be working properly, both filling up and draining with no leeks.
Non Rotten side
Where the cranking battery was sitting, started pulling up all the rotten wood.
U can see the hull in this picture where the water was sitting.
I'm just at a lose here and don't know what to think or where to go.
Any suggestions or thoughts, would be greatly appreciated. Thanks
Non Rotten side
