stjoeislandkid
Thread starter- Joined
- Nov 17, 2010
- 10
is there any way to tell if your boat is water logged or if there is water getting in under the floor in the foam? my boat seems to be in very good cond even if it is 22 years old. i,m the second owner and it only has 182 original hrs on it. the boat is a searay 200 bowrider with a 5.7 mercruiser. iknow this boat weighs about 3500 lbs and is heavier than alot of boats the same size.. there are no soft spots in the floor anywere including under the seats and near the transom.. my problem is this. other boats similar to this one are getting around 54 to 57 miles per hr at wot. i can do about 50 at wot and the motor runs perfect at 4500 rpm. i.ve tried different props but don.t make alot of differance. gets up on plane no problem and will rev to mercs specs about 4200 to 4600 no problem. a friend suggested maybe she,s waterlogged and it has got me to thinking, i just don,t want to tear up the floor and was wondering if there was another way to find out. any suggestions would help thanks in advance......
