Water in bottom of cover
jerkputter
I run my 2000 model 50hp mercury 2 stroke today on my pontoon boat. I was going to check some things being I just installed a new powerhead and noticed water was all in the cowl almost even to bottom coil. I could not find any way to drain this water out. I used the power trim and lifted engine to remove the water. What could cause this. I never remember this happening in the past ? I know it blew off a very small oil line going to block last week and filled the bottom up with oil and gas. Got a new line and replaced it with tie straps so it should not come off again. Any idea where to look to see what is plugged up ? where this water will get out ? Thanks. Tom
Chris1956
Obviously, start the motor on the flusher on in the water, cowling off. See where the leak is. Post back....
jerkputter
Run the boat engine with cover off before I posted and I see some water dripping from side of block , I just cannot see where. I cleaned all the oil with an engine cleaner. The water pump is pumping a good stream out the back of engine going out of cowl and the line is not broke. I got hot trying to find where it was leaking and called it a day. I cannot take the summer heat especially on the water working. I will look more tomorrow as its supposed to cool off some.
jerkputter
It is not leaking anywhere on the motor so its got to be coming in from the outside. I let it idle today for at least 30 minutes and no leaks. I have a good stream coming from the block to outside of cowling so the water pump is doing its job. There seems to be a hole opposite where the fuel line goes in on front of bottom cowl. It is about 1 or 2 inches long and about an inch high. Looks like a plug should go in it. I will have to drive the boat and look while someone else drives it. I am betting that's where the water is coming in. The motor could also be sitting to deep in the water. I need to check that also.
jerkputter
Number 40 is missing on bottom cowl so I am thinking that's where water is getting in
jerkputter
jerkputter
Do you think that number 40 is the plug I need and the one that is missing ? Thanks for any tips but I think that is it
