kbait
- Joined
- Nov 13, 2007
- 2,486
Replaced impeller/thermostat recently, and upon next run wouldn't idle well. Checked plugs and found water on lower one. Pulled head, and sludgy looking watery/fuel mix found in both cylinders (more in bottom one). Replaced head gasket w/no improvement (water still evident on plug). I have ordered bypass cover gasket and exhaust cover gaskets, but was wondering if that's indeed the cause, as it happened immediately after aforementioned service. Water tube seemed to stay w/powerhead normally during lower unit removal/installation, and cools normally. Could I have folded the upper grommet over, even if it stayed there during service? Would that cause water intrusion into the cylinder anyway? Any thoughts appreciated! (you too, BK)
