Water in cylinders, mercruiser 3.0
arrkerr
Last weekend I was out on the lake and ran across a stupid sand bar hiding in the middle of the lake. I hit some sand, motor bogged a bit, and I killed it and raised the motor. It wouldn't start, and it turned out my brand new starter was cheap and the cone cracked and after further examination may not have been the right part. I was towed back.
I got my old starter repaired this week, and put it in. It cranked a bit and then froze. I immediately pulled the plugs, and water shot out.
I've read that bad exhaust manifolds are the common cause. Is there any chance that the boat is fine, and water came in due to me almost stalling it on sand and the starter cracking?
I've got the manual, but figured I'd ask people with more experience first.
Thanks!
JustJason
Re: Water in cylinders, mercruiser 3.0
Sounds more like you hit a sandbar, sucked up a bunch of junk and ran your motor until it overheated. Now you either warped your head, cracked your manifold, or both.
Cracking a starter isn't going to happen from hitting mud.
arrkerr
I never re-started the motor after hitting the sand. I couldn't, the starter was broken.
On closer inspection, however, the starter had a slightly different head. My guess is that either the flywheel wacked it (but there aren't any signs of impact), or that I hydrolocked the motor and the strain of trying to turn the motor caused it to crack along a defect. I've already established that the starter was a cheaply refurbished unit.
arrkerr
Thats the for document, CheapboatKev. That should be a sticky under the adults only section.
CheapboatKev
No Problem..Glad I can help as I have been here!
