ericp501
Thread starter- Joined
- May 14, 2011
- 149
96 mercruiser 4.3.. Bought the boat not knowing the starter bolt mount was cracked and jb welded very poorly.. I cranked it over about 50 dif times before the jb weld finally gave up. I used a lot of kwik steel to get the bolt back in the right position and now need to put a starter brace on to stop it from torquing out of place again. Is it possible water is getting into my cylinders and making it hard for starter to turn over the motor and thats why the mount cracked? If I have someone push out the starter with a crowbar acting as a brace the engine will turn over in about 2 seconds, otherwise I hear a loud "clunk" sound and nothing, had a backfire once after the clunk.. Otherwise, once the motor turns over she runs pretty good for a long time.
Is there any way or signs I can check to see if water is leaking into my cylinders? Like pull the spark plugs, attach muffs and turn it over for a few seconds to see if water starts coming out? Would the oil look a certain way if water was getting in?
Or am I just over thinking all this, and all my problems are prob coming from that broken starter mount?
The first pic is of the missing chunk from the mount and a brace I tried making.. didn't work
the second pic is of the chunk fitted back on and a lot of kwik steel used to to get the starter in the right place again. (I haven't tried starting it like this yet, I'm giving it a week to completely cure before trying it.)
