Hello everyone,
I'm new to this forum. I always use Powerboatparty.com. I'm hoping I can get some help over here also. I have a Brand new 454 roller motor.(500hp) I got water in it after 1/2 hr. last time due to cracked exhaust manifold. Found out after it was pressure tested, replaced it. This time I have 9 hrs on it and found water in it again!
Now a very short history of the situation. Professionally built; 90% sure it is not reversion; oil cooler, heads, manifolds, and risers have been pressure tested and are all good. Also I have external flaps on thru-hull exhaust. Brand new gaskets on the risers(factory mercruiser), but I only put copper high-temp silicone on the exhaust manifold. Which is what the engine builder said to do. I'm almost positive I did everything right. I was raised a gear-head by my dad. But that is in drag racing.
Any suggestions would be greatly appreciated. And I'm getting broke off this engine!
