legalfee
- Joined
- May 10, 2018
- 426
I ran my 95 90hp low on gas and it shut off. I had to use starting fluid to get it going again. I assume it was water in the bottom of the tank. I put some Heet in the tank and 10 gallons of pre mix. Now the motor is very hard to start. It's almost like fuel is not getting to the carbs.
My enricher is not working so I normally use starting fluid. In the past after starting I could cut it off and it would restart easily unless I let it sit more than a day.
I'm wondering if I need to change out the fuel pump and filter. (I don't have a water separator).
Thanks for any ideas.
