Water in fuel tank
99yam40
Re: Water in fuel tank
Drain the tank and clean and dry it out.
Also clean/flush out all lines,filters, and pumps
If you have any ethanol fuel it will absorb the water and separate out ruining the octane rating of the fuel
renegade15
In addition to starting with a clean water free tank, I am also a big believer in the racor or similar style 10-micron fuel/water seperator spin-on filters. Especially the ones with a clear bowl on the bottom of the filter, so you can not only see if there is any water in your fuel since it settles to the bottom, but also if there are any particles coming out of your tank or throught your fuel lines. And the nice thing about the racor is they have a little valve so if you do see any water or debris in the bowl you can drain it out without having to remove the entire filter. Worth every penny in my opinion. I also put sta-bil marine formula stabilizer ethanol treatment in my gas, but I will probably switch over to valvtect when my sta-bil runs out.
Chris1956
Stripper, Siphon the bottom of the tank into a couple of jerry cans. Let them settle and then siphon them into a clear gallon container. You should be able to see the water and can pour off the good gasoline. Use some 2 cycle oil to tint the gasoline if you have trouble seeing the water. it is not recommended to treat any significant amount of water with additives.
dingbat
I agree.
STRIPPER2223
that's alot of siphoning to do... is there another way...i have about 50 gallons of gas left in the 100 gallon i have.
Chris1956
All the water will be on the bottom of the tank. If you siphon 10 gal or so, off the bottom of the tank, you should get all the water.
Chris1956
Tilt the boat so all the water runs to the rear bottom of the tank. It will be easier to get it out.
Capt.Ron56
Stripper,I would invest in an inexpensive in line fuel pump from any auto parts store if I had that much fuel to remove.
Lakes84
THIS is the bomb. It's what I used....worth every penny.
