It's not a ton, but it was all through the drain of the lube so that's enough. Was originally planning on doing the impeller and other associated maintenance but that's on hold now. Going to set it up for a pressure test and see where it is leaking from sooner than later.
Being this drive is a mix/match to begin with (unknown upper for proper ratio, lower dad built from the parts from junk boats at the shop 30 years ago he is constantly surprised is still together and is a preload pin model) I will be taking a long hard look at what I'll do moving forward. Any water that got in is brine, so that's not a great start. I have most of the tools to do a rebuild and reseal and if not I can borrow from a friend...
That being said, the SEI with a 3 year warranty looks mighty tempting.
More to come, mostly just looking for moral support on this one.
