water in lower unit oil
g7mcon
how did i get water in lower unit oil on johnson 48 spl
Vic.S
Re: water in lower unit oil
A seal has failed.
Prop shaft one most likely because they get cut up by fishing line.
Could be the drive shaft seal, possibly even the shift rod seal.
It might even be simply the sealing washer on the drain or level plug if you have reused the old ones!
