patrick4266
Thread starter- Joined
- Nov 29, 2007
- 591
I have a 1970/ 85 hp rude model 85093. I removed the bottom lower end grease screw and a small amount of water came out. Should i remove the lower unit and try to fix the leak? what gaskets or seals do i fix? Is there any tricks or something special i should know on this motor? This will be my first attemt to work on a boat motor but I am a auto machani so I understand motors, just not out boards. also should I replace the impeller while i am there? I bought the evenrude service manual from abay so I have that to go by but I still need some advice. thanks
