Water in lower unit??
Oldtimer1
just bought a 92 88hp spl johnson....i noticed it had a little milky water in the lower unit when i drained the fluid, i noticed that the screws didn't feel all that tight when i loosened them up, when inspected the o rings, they looked to be in good shape so i filled up the lower unit with fluid and went to the lake for 4 hrs, got home and checked again and there was a little milk still coming out but when i plugged the hole off and inserted a new tube of fluid and shoved it in until clear fluid was coming outta the top whole...the little bit of milky fluid that came out the 2nd time, i am wondering if that was what was left over from the first time i drained it???
jonesg
Re: Water in lower unit??
You need to use new seals on the drain screws.
Flush and refill, (or at least leave it to drain a few hrs)
buy extra seals and recheck after an outting,
that should fix it good.
Oldtimer1
thanks alot for getting back to me!!!! great info!
Oldtimer1
oh just wanted to say that i did change the seals and a little water is still getting in for some reason?? any thoughts on why? thanks in advance...
lindy46
Other seal(s) leaking somewhere in the L/U.
