LinkAmerica.net
- Joined
- Jun 16, 2003
- 15
Hello,<br />I have a 90 OMC Cobra 5.8L engine with an OMC stern drive. Last year I was getting water in the oil. I took it apart this year and found I had a cracked intake manifold. I could not find a replacement so I replaced it with an Edelbrock Performer intake. The crack in the intake was letting water get into the well where the pushrods are on the 351. Got the intake on, sealed everything, checked everything out, runs fine. Put it on the muffs and changed the oil and filter and it had no extra fluid in it for about 30 mins of running on the muffs. Took it to the lake and ran it for an hour and a half and brought it back home, it has twice as much fluid on the dipstick as it was before. Why would it run fine on the muffs and not in the lake? What would be the difference, maybe more pressure in the lake because your running higher rpm's? Is there any way water could be getting into the engine from the transom or is the hose that comes from the impeller the only access for water? Also, could it be a water pump problem? Is there any access water can take to get to oil from the pump or is it just a bolt on accessory? I believe the intake cracked because of excess heat. Last year the engine ran for about 10-15 minutes with absolutely no water in it after a year of sitting. So maybe a busted head gasket? Maybe a cracked block or head? <br /><br />Any help would be great.<br /><br />Mike
