water in pistons and oil pan
ve4jnf
I have a 5.7 l engine every once in a while the pistons and oil pan will fill with water. I have to take the spark plugs out and drain the oil.
Then the engine runs fine for months. Idont get it need some help.
LX Kid
Ensign
Re: water in pistons and oil pan
If it were mine I would start with a vacuum guage test. If you are skilled with how to read one and recognize what it telling you it can be a very good indication where the problem area might be. I'd then do a compression test on all the cylinders. If you don't have good diagnostic skills it's going to be a little tough. You may wind up having to seek out a professional mechanic. Water in those places just don't sound good at all. Could be a lot of differant things. Intake manifold gasket, head gasket, etc. Keep us posted. And then againn it could be none of them.
franktrav
#1 cause of water in cylinders is from leaking exhaust manifolds/risers
check that first
