Ridewright79
Thread starter- Joined
- Jan 2, 2013
- 46
Re: Water in starboard cylinders only. No water in oil. 5.7 Mercruiser
Ok so here is what I found. I looped the hoses on the tstat housing and pressurized the cooling system. Would not hold pressure. I could hear the pressure leaking on the starboard side with the plugs out. So I removed the manifold and can hear air coming out of atleast two cylinders. Looks like the head is either cracked or gasket failure. Either way they are coming off to inspect the pistons and cylinders to see if there is any damage. Also have to send them off to be checked. I am very familiar with SBC so it is not too bad. Any suggestions on brands of gaskets to go back with. I know victor makes a marine set but wanted some advice on a good set.
