Hello members,
I started to get the boat out for the spring and think I have a problem. while the boat starts and actually runs fairly well, there are a couple issues. the first is that there is a ton of white smoke (I thiink its actually steam) coming out of the exhust and also I clearly have water in the oil.
Now I know the steam / smoke issue has to be a cracked intake/exhaust manifold. What I'm not sure of is if this is the right cause of the water in the oil.
I removed each plug and tested the compresion of each cylider and each one tested out with good compresion, none of the plugs looked wet either. So I'm strugelling in my head about how a cracked manifold is letting water into the oil. If its taking water into the intake vales would that not make it run very poorly if at all?
I've priced out the manifold and its about 300 new. I just don't want to bolt on another 300.00 just to find its got a bad block and was a waste of money.
The motor is a 1981 mercrusier 120 horse 4cyl (the iron duke).
Any help or advice on other things to check would be greatkly appreciaited.
Thanks,
Doug
Thanks,
Doug
