northcreek2624
- Joined
- Jul 27, 2007
- 8
Just purchased a used 99 GS 160 from a Glastron dealer.
I have a concern that may or may not be a problem.
While installing a depth finder tranducer I had to drill two small holes about two inches up from the bottom of the transom,the holes are one inch deep.
Although the drain plug was out and floor dry I had streams of water shooting out the holes.I then put a vacuum pump to the holes for eight hours to remove all the moisture and then put sealed screws into the holes.
After using the boat the water was back.
Iam concerned that this trapped water will rot my transom wood if it hasn't already.
Any insights/ideas?.....thanks,Mike
